Thread
Why do a grill block when you could put excess air to good use?
09-19-2011, 02:40 PM
22
permalink
Patrick
Hot Tamale
- '10 Toyota Prius III
You might be able to make it work if you have extensive ducting to, through, and after the radiator ala P51 Mustang or Walter Korff. Place the turbine in the flow after the radiator to get a "jet engine" effect from the expanding heated air.
Patrick
View Public Profile
Send a private message to Patrick
Find More Posts by Patrick
