Old 09-19-2011, 05:54 PM   #44 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Originally Posted by silverinsight2 View Post
Why draft so close? You can get a portion of the effect further back and it's a lot safer.
Drafting behind a big rig will improve your car’s fuel efficiency.
confirmed
To test this myth, the build team procured a car, a big rig, and a device that could measure a car’s fuel efficiency. They then drove the car behind a moving big rig at various distances ranging from 100 to 2 feet and measured the amount of fuel the car consumed. The Build Team discovered that the closer the car was to the big rig, the less drag is produced, thus the more fuel saved. At just ten feet, the car managed to increase its fuel efficiency by 40%. Drafting at two feet was slightly lower than the ten foot distance, mainly because Grant had to keep working the car pedal to maintain distance from the truck. However, that did not dispute the fact that drafting actually can increase your car’s fuel efficiency. However, the Build Team has warned that drafting is incredibly dangerous because the truck driver may not able to see you and you may not be able to react in time if the truck were to make a sudden stop.
11% at 100 feet with a 1 second reaction time. Good luck with that.
