Old 09-19-2011, 12:27 PM   #41 (permalink)
Cd
Ultimate Fail
Cd's Avatar
So I saw this gasoline tanker cruising along and thought I would give chase.
Old 09-19-2011, 12:50 PM   #42 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
The biggest danger in following too closely isn't necessarily the stopping distance in front of you (assuming you're not napping at the wheel).
Following too closely makes you a reactive driver, instead of a driver that anticipates based on what is happening down the road. It's even more true if you're following a big vehicle that you can't see past.
When you're too close or can't see, you're more at risk of being run into by the driver behind you because you have to brake as hard and as fast as the vehicle in front.
I'd rather use a big safety cushion in front to absorb changes in speed more gradually, and give the tailgaiters behind more time to aviod smashing into me & each other.
Very good points to consider.
Again, regarding the reaction time again, it is extremely challenging to maintain a hair-trigger on your brake for any length of time. I've done drag racing so I know how difficult it is to keep focus even for a few seconds before the tree drops. If you want to draft for more than a minute or two, I guarantee that drafter's reaction time will extend to 1 second or more. That can be deadly.
I'm not coasting, I'm shifting slowly.
Old 09-19-2011, 03:49 PM   #43 (permalink)
Why draft so close? You can get a portion of the effect further back and it's a lot safer.
Old 09-19-2011, 04:54 PM   #44 (permalink)
UFO
UFO's Avatar
Drafting behind a big rig will improve your car’s fuel efficiency.
confirmed
To test this myth, the build team procured a car, a big rig, and a device that could measure a car’s fuel efficiency. They then drove the car behind a moving big rig at various distances ranging from 100 to 2 feet and measured the amount of fuel the car consumed. The Build Team discovered that the closer the car was to the big rig, the less drag is produced, thus the more fuel saved. At just ten feet, the car managed to increase its fuel efficiency by 40%. Drafting at two feet was slightly lower than the ten foot distance, mainly because Grant had to keep working the car pedal to maintain distance from the truck. However, that did not dispute the fact that drafting actually can increase your car’s fuel efficiency. However, the Build Team has warned that drafting is incredibly dangerous because the truck driver may not able to see you and you may not be able to react in time if the truck were to make a sudden stop.
11% at 100 feet with a 1 second reaction time. Good luck with that.
Old 09-20-2011, 02:14 AM   #45 (permalink)
Bow
Old School Hashiriya
Bow's Avatar
Fred - '98 Nissan Frontier XE
90 day: 26.57 mpg (US)
I do it... Well, I use too in Texas (no freeways up here in Southern Maryland...)
But I'd jump on the CB and ask the driver if he'd mind me sliding in behind him and saving some gas...
99% of the time, they didn't care, and on a long run, we'd strike up a conversation.
I ran from Houston of Oklohoma City like that in my '91 240SX fastback. Running 85 mph, A/C on, no cruise control, and drafting, we got 45+ MPG.... the wife was snoozing and I was BS'ing with the truck driver...
Bottom line, if you ask, they are usually cool with it, and will warn you if there is something coming up in the road....
Bow
Old 09-20-2011, 04:21 AM   #46 (permalink)
HighMPG's Avatar
Super Duty - '12 Ford F250 Super Duty XLT Long Bed Super-Cab
90 day: 15.29 mpg (US)
This brings back some memories when my pops had one in the jeep, I was like 8 and would hop on and start scanning channels for people to talk to. It also reminded me of "Smokey and the Bandit" and"Knight Rider" "Air Brakes" to slow down from super pursuit mode. lol
Good Bye Insight Hello 6.7 Diesel Truck!
**My First Hybrid Insight**
Old 09-24-2011, 01:14 PM   #47 (permalink)
I did use this technique and didn't seem so dangerous - except for the flying rocks part. Longest run was for about 25 miles at constant speed of about 55 mph. I kept a distance of about 20 - 30 feet. I didn't measure the mpg, but overall I had a good FE for that trip.
Old 09-24-2011, 02:26 PM   #48 (permalink)
Wannabe greenie
The Clunker (retired) - '90 Honda Accord EX sedan
90 day: 29.49 mpg (US)
Mountain Goat - '96 Ford Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '10 Kymco Agility 125
90 day: 65.03 mpg (US)
When I had my long commute, I used to do that on the 60 freeway. Of course, all traffic was moving at 45-55 mph, and I'd stay several car-lengths back. My concern wasn't so much that the truck was going to slam on his brakes, but that he'd see a wooden apple box or something and just high-center it, leaving me to eat it. However, since he was following other cars, it seemed less of an issue. (I could tell if they were swerving out of the lane to avoid something.)
Old 09-25-2011, 04:46 AM   #49 (permalink)
I don't know if it makes a big difference or not, but if I decide to draft behind a big truck, I check to see if it has wheel spats, so that rocks or pieces of wood don't fly right up.
Old 09-30-2011, 05:08 PM   #50 (permalink)
The PRC.
2 second rule. If you can say "I always follow the 2 second rule" in the time it takes the vehicle in front to pass a fixed point and for you to reach it, thats safe.
Big trucks make a big hole, you can be safe and still gain.
Plus being further back means your window is less full of truck, so you get to see more of the road ahead.
Reverse drafting: how to slow down on the hwy and not hold up traffic MetroMPG Hypermiling / EcoDriver's Ed 30 04-13-2013 05:21 PM
Drafting, it puts me beside myself with laughter NoCO2 Aerodynamics 14 09-15-2011 12:52 PM
Drafting off center? dissimilation Hypermiling / EcoDriver's Ed 5 12-29-2007 01:48 PM
