Old 09-20-2011, 08:57 AM   #12 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
You might be on to something.
I have read that 10.8 is where you need to stop using the battery. I would up that to 11 volts even.
Is there any posibility you can put more solar power on your car?
This set up currently runs without the panels. Originally, I had thought I would install 100-120 watts on the roof, fill the whole area. That costs for the new, 2.5mm thick, cells I planned to buy. Now I am thinking minimum 20watts (min 1.5 amps) or maybe doubling that. Such a set up is more affordable and fits nicely on the aft portion of the roof. I may be able to aeromod the part that sticks up to look like one of those quasi, mini shark-fins. I want to run the radio or fan or both without radically depleting the battery on my daytime 22 mile commute.
Another good thing to know is the lower your system voltage goes the more amps out of your solar panel.
The panels I plan to build for my truck for example, the 6x6 cells I have should make a panel good for between 4 or 5 amps at 14.5 volts, but when the system voltage dropps off to 12 volts and less the amps from the panel should rise into the 5 to 6 amp range.
This is why I am wiring up those salvaged 0.4 amp float charging panels for 22.5 ocv, that way I get the whole 0.4 amps any time the sun is on them. I have tested them and they are good for holding battery voltage on 2 large truck batteries just over 13v.
This is very interesting. How are you wiring it up.
