Thread: The Deadly Heat
Old 09-21-2011, 01:44 AM   #58 (permalink)
Sven7
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Originally Posted by rfdesigner View Post
One idea I came across in Hong Kong was very simple.
A lot of taxis had a roof fitting that created a partial vacuum across the entire roof of the car. Essentially it was a plain aluminium item, with a small air inlet at the front and a much larger exhaust at the back, thus as the car moved forward the air just above the roof would be lower pressure than normal and hence cooler, thus the cabin would in turn be cooled. Drag was fairly minimal, mainly just the added frontal area.
Add to this to a solar powered fan to keep the air inside the car changing while parked, thus meaning the air temperature never gets silly, a chair bead thingy to keep air moving beneath you, and some reflective window tinting and it might all be enough.
Derek
On similar lines, maybe have an air duct somewhere inconspicuous in the top of the cabin (where the hottest air is) and direct it through a hole in the back of the roof. The passing airflow creates a low pressure zone and sucks the hot air out of your cabin. You'd need the HVAC on "vent" to let cooler air in.
Also, tint your windows as dark as is legal (especially the back one!) and use a sun shade. Maybe try to find a louver for the back, as that would all but eliminate solar gain.
