Old 09-21-2011, 04:19 PM   #34 (permalink)
wildthings
173 MPG Honda
Hey guys- here is an update at the final hour: Both engines turn freely. I put a socket on the flywheel of the diesel and could hear compression as it turned. With the car in gear, I pushed it and could see the piston move on the gas motor with the spark plug removed. I have a feeling it would take little to for a good mechanic to have this in motion in moments! The car has a clutch, but the stick has two cables and I am not sure if the linkage is similar to a motorcycle as it has an odd shift pattern. The seat upholstery is in very good condition overall that reflects the low miles. The nasty shag carpet has GOT TO GO! Good luck bidding!
