Originally Posted by ChazInMT
Brucey Babe...I was thinking of doing something similar to my 04 Civic, my plan was to design it so it had pressure points on the top of the class and rear or the trunk lid, then I was just going to put metal bracket hooks on a cinch strap and hook the front of the trunk lid on the outsides, then pull tight, so it would only rub on the car in 2 places, and the hooks would contact the bottom of the front of the trunk (bottom of the rear glass area) that nobody would ever see. It wouldn't move cause you are jamming a "V" into a "V" shaped hole essentially. I'll post an illustration later, on the road right now.
I think I get your idea. Pulling the spoiler assembly forwards against the glass and down against the trunk lid. I think you would need to take it off the car to open the trunk - but maybe you have a way around that.
