[QUOTE=Artan;262592]
We are talking about internal comustion engines, it is the same, petrol diesel, small, big, just engines that contain oil inside. metal, bearings etc. If a very big truck pulling very heavy weights working non-stop for very long intervals would last very long without oil change why wouldnt a very small car that transports very light weights compare to the truck.
You are a professional Old Mechanic i dont expect you saying oil should never be changed cause you will loose your job.
You dont convince me ever. I will never change the oil!
Regards,
I wish I lived in your world, where everything is simple!
I bet Old Mechanic is retired now, so he doesn't need to feed the conspiracy. I'll also bet he's seen plenty of damage from lack of basic maintenance - like changing the oil.
Nobody thought anything could change your mind at this point in the conversation.
Jay
