Originally Posted by Lazarus
Any thoughts on filling the filter( shown at the faucet) with vinegar to keep the hard water at bay? I imagine if you filled it once a month with as little as the mister put out it work work well with the timing change of the inside filter.
That's a thought. Since it's a 5-micron filter, I wonder if the acidic properties of vinegar would break-down the filter medium?
Maybe at every other mowing, stop at the unit and spray a vinegar solution onto the fins?
RH77
