Old 09-23-2011, 03:54 PM   #92 (permalink)
user removed
[QUOTE=Artan;262592]
We are talking about internal combustion engines, it is the same, petrol diesel, small, big, just engines that contain oil inside. metal, bearings etc. If a very big truck pulling very heavy weights working non-stop for very long intervals would last very long without oil change why wouldn't a very small car that transports very light weights compare to the truck.
You are a professional Old Mechanic i don't expect you saying oil should never be changed cause you will loose your job.
You don't convince me ever. I will never change the oil!
Regards,
Your ignorance of internal combustion engines is apparent to any reader. There are large diesel engines that run 24-7 for years. They generally run at very low speeds, sometimes less than 100 RPM.
If you think that is the same as a model airplane engine running at 42,000 RPM, then you need to educate yourself.
A brain is a dangerous thing to waste and the ultimate cost of wasted brains is loss and poverty.
I'm finished here, not interested in free lessons. Try using spell check in your posts.
regards
Mech
