Originally Posted by Sven7
I am, thanks. Does it have a clutch, though? Because that's half the point of a manual.
Note sure - Its actually called Multi-Mode Manual and is a 5 speed, but I will have a look at the handbook which explains it all - common to both transmissions.
EDIT - there is no info in the manual except how to start it with the MMT (shift to N, press brake pedal). This definition is on the Toyota website
MMT - MultiMode manual transmission
M/M uses the same mechanical components as a traditional manual, but with an electronically controlled clutch. Accelerator pedal should be treated in the same way as on a conventional manual but ease off slightly when requiring a gearchange. There are three mode settings:
M - Manual Mode (Sequential) for dynamic driving
Full control of gear changes
Real manual feel
Quick gearshift
Sequential sporty feel
E - Easy Mode (Automatic) for comfort and economy
Shifts are made for the driver
Manual transmission with clutchless gearchange
Accelerator control similar to standard manual
Es - Easy Sport Mode (Automatic) for sportier shift pattern
Shift pattern has been optimised for sportier performance
Recommended ‘auto’ mode
Those are still FWD, silly. Well, some are AWD but those were more expensive. No one makes RWD economy or midsize cars anymore- they're all luxo or sport rockets.
Ironically my Avatar was criticised when he made the idea of transverse engines and FWD popular in the 1960s. He was told his cars handled "too well" for ordinary people.
