Got my new "pigtailed" version in the mail on Thursday; just installed it in my '00 Civic HX. I'm feeding +12V and ground from my stereo's wiring harness; the injector and vss signals are coming from my ECU (called ECM in the Honda manual). A word of caution: be very careful when stripping the injector and vss wires. I got a bit overzealous in stripping the vss wire, and it snapped. Thankfully there was just enough left to strip off each end of the break and twist/solder them back together. I could easily have not been so lucky and forced to replace the cable on the plug side of things.
