Originally Posted by jorymil
Ooh! I like! Those things would have saved me about an hour's worth of work--not to mention not needing an inverter for my soldering iron. Oh well--the burned hand teaches best, especially when it gets burned by a soldering iron!
I used to work installing car electronics and do all my own so learned all the tricks during the last 20 yrs!
fusing them together is the best sure way tho.
JOE123,
I think they can run on it's own but you can add the Arduino to handle more readings, options, and even program to run things?
I did not look much into it tho but it seems to be a open source/ programmable piece of hardware you can use to monitor and control other things. Maybe like signal your motor to do something early or turn on a warning light ?
