Old 10-01-2011, 08:10 PM   #20 (permalink)
deathtrain
Black Knight - '94 Toyota Corolla
90 day: 58.53 mpg (US)
Well i am back and will up date my progress here more. I am at 125% over epa so i think i am doing good. for a full up date read this post on the % mpg battle that was started.
http://ecomodder.com/forum/showthrea...epa-18075.html
the result of that post I actually got into some mods now. I did a 3/4 grill block for now and installed some smoothies. I need to get some sheets to do my belly pan and too do fill in the wheel gaps front and rear.
*edit*
Here are some pics of my dash and crappy temp gauge that i have. you can see my speed and the engine temp. outside temp was over 100 so with this block off i don't think i have anything to worry about next summer. even getting off the freeway at this temp this is the highest that my needle goes. Also with the cooler mornings i don't even get out of high idle. my temp gauge is about half what is it in the pics. with this crappy oem gauge and no markings is the main drive i want to go with an aftermarket one. this way i can see whats going on a lot better.
