Old 10-02-2011, 11:35 AM   #36 (permalink)
redyaris
redyaris - '07 Toyota Yaris
90 day: 45.54 mpg (US)
Gray - '07 Suzuki GS500 F
Motorcycle
90 day: 70.4 mpg (US)
streamliner1 - '83 Honda VT500 streamliner
Motorcycle
90 day: 75.63 mpg (US)
White Whale - '12 Sprinter 2500 Cargo Van
90 day: 22.01 mpg (US)
Originally Posted by Old Mechanic View Post
The flaw in Sentra's testing of a WAI is the climate in the region where he conducted the test.
Try it in 20 below temps and give us your results.
regards
Mech
I agree that the test results are too small of a sample to draw a general conclusion about warm air intakes. The test itself is a rellavent sampling in that it shows that in areas with high ambient temps the under hood temps are high enough to eliminate the benefits of WAI. I have varefy that myself when I sealed off the rear of the engine bay hood [...better aero...] and took the hose off of the above exhaust hot air collector and stuffed it into the corner of the engine bay on a hot [30*C] summer day and the intake air temp on the scanguage only dropped a few [less the 5*C] degrees. I did this because I emagined that the intake air was getting to hot. Winters here get down to minus 20*C or colder so during cold weather WAI may still provide a FE benefit.
