Old 10-02-2011, 12:06 PM   #1 (permalink)
Kodak
Kodak's Avatar
Canyon - '07 GMC Canyon 2wd regular cab
90 day: 24.95 mpg (US)
Understanding aero vs throttle pos.
I read a post the other day (can't seem to locate it) that confused me a bit. Maybe I misread it.
Here is what I know: Aero improvements cannot change engine rpm for a set gear and speed because gear ratios are fixed. Aero improvements can only decrease the required throttle position to maintain that speed, by putting more engine power towards forward motion (versus overcoming wind resistance). One could opt for a taller final drive ratio, but that's a whole different story.
But here's the part that tripped me up: In some situations, the lighter throttle position invites more pumping losses? I can't wrap my head around a situation in which better Cd, which means lighter cruising throttle pos., could have a negative result.
Perhaps pumping losses are increased, but it's still always a net gain - right?
I'll try to see if I can come across the post, but I think I explained it correctly.
EcoDriving: Turning more fuel into usable forward motion.
