Old 10-02-2011, 07:33 PM   #7 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Originally Posted by JRMichler View Post
Correct, it's always a net gain. I read one paper (don't remember title, when, or where) that said the real world gain for aero improvements alone is about half the total drag reduction. You get the rest of the gain by gear ratio changes.
Makes sense to me.
I would also say that with better aero, you're able to coast more often and for a longer distance. This reduces your rpms to either zero or idle speed, depending on your preferred coasting method. Of course, that's once you've added coasting to your "tool kit". So depending on your route and the hills etc., I believe coasting WITH improved aero can give more benefit than just what you gain from drag reduction alone.
Coast long and prosper.
