Despite the ultimate "Ghetto" look, I was even considering using the aluminum roofing tape for my wheels. Straight strips across the wheel until it is fully covered and if I felt the need, smaller strips wrapped over the lip in order to hold the ends in place. The tape is strong and chrome, anything wrong with doing that?
If you need to service a wheel then poke a hole in it and re do it when you get home ...
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
