Old 05-16-2008, 06:07 PM   #21 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
Despite the ultimate "Ghetto" look, I was even considering using the aluminum roofing tape for my wheels. Straight strips across the wheel until it is fully covered and if I felt the need, smaller strips wrapped over the lip in order to hold the ends in place. The tape is strong and chrome, anything wrong with doing that?
If you need to service a wheel then poke a hole in it and re do it when you get home ...
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 05-17-2008, 07:28 AM   #22 (permalink)
Whitey - '05 toyota corolla LE
90 day: 28.91 mpg (US)
Send a message via AIM to blackjackel Send a message via MSN to blackjackel Send a message via Yahoo to blackjackel
I just realized something...
these are STELL... they are gona rust up on you something aweful
Old 05-19-2008, 11:52 AM   #23 (permalink)
ScabbySentra - '93 Nissan Sentra SE
90 day: 44.37 mpg (US)
The ones bought have a non-stick coating of some kind on them. If they start to rust, I can spray on some primer.
Old 05-22-2008, 07:55 PM   #24 (permalink)
coasting....
You can get stuff like that powder coated pretty chaeply if you choose a common color (white, black, etc) and sometimes a 12 pack will do wonders...
If you want to paint them yourself, use Rustoleum Appliance Epoxy. $5.00 a can (give or take) at Orchard Supply.
Old 05-22-2008, 10:18 PM   #25 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Spray them with PAM to keep food from sticking and keep them rust free
GeoMetroforum.com - got mpg?
Old 06-01-2008, 01:04 AM   #26 (permalink)
Recycling Nazi
Bror Jace's Avatar
Blue Bullet - '06 Honda Civic Sedan LX
90 day: 35.68 mpg (US)
Arrow
I was at our local "Christmas Tree Shoppes" which is a (small) step-up from a dollar store. There they had some type of an aluminum tray (with flimsy plastic lid) they referred to as a 'dessert tray.' It was lighter than steel. The reduction in weight is always welcome ... but the lighter weight may also mean they will be easier to keep on. They were also larger than 12" or 13" ... for those of us with larger rims (My Civic has 16" wheels).
Maybe these dessert trays are aluminum clad cardboard? They had a design molded into them that was hideous. That was the worst part, I think.
I think I'd rather have plastic ... then I can spray paint it black, silver or body color.
Still, I'm dubious of having anything permanently attached with magnets (that I'd have to source).
--- Bror Jace
Old 06-01-2008, 01:35 AM   #27 (permalink)
Blue - '77 Chevy P/U
i check tire pressure every other week so i need something that is removeable
Old 06-01-2008, 10:17 AM   #28 (permalink)
90 day: 57.73 mpg (US)
COMP: you could drill a small hole and use a valve stem extension.
Old 06-01-2008, 10:19 AM   #29 (permalink)
not on the truck,,,i have short stems in so they can't be torn off
Old 06-02-2008, 02:40 AM   #30 (permalink)
Grrr :-)
Nerys's Avatar
Cherokee - '88 Jeep Cherokee
90 day: 19.44 mpg (US)
Ryo-Ohki - '94 Geo Metro Xfi
90 day: 50.15 mpg (US)
Vger 2 - '00 Plymouth Grand Voyager SE
Ninja - '89 Geo Tracker
90 day: 30.27 mpg (US)
The only problem I have is on some cars they do not look nice so I came up with a solution. I have no tried it yet but I will give it a shot. I am going to Heat up a piece of plastic and make it into a "bowl" the shape of my hubcap. Attach once inside and outside. This will do several things. One make them smooth like these pans you guys are using. (awesome novel idea BTW!! I do not think it ever would have dawned on me to use them like that) Second its clear so they are invisible and third they are clear so you can still have nice hubcaps and aerodynamics and putting BLACK on the inside will keep the caps clean and brakedust and dirt off :-)
My problem is I only have 2 of 4 caps. Some smucks stole two of them while we were in philly moving my mother out. $5 a pop and they just had to steal them. Alas I can not find them again and all the "current" hubcaps I would not be caught dead putting on my car they are so butt ugly :-(
List of aero mods you can do to your vehicle MetroMPG Aerodynamics 148 08-12-2021 11:53 PM
LRR (low rolling resistance) tires - Green Seal report & list MetroMPG EcoModding Central 46 06-05-2015 05:24 PM
Plate Hubcaps Nerys Aerodynamics 8 05-08-2008 04:41 PM
Aero hubcaps thebrad Aerodynamics 5 04-09-2008 02:08 AM
Another Autospeed aero article: methods for measuring aero drag Daox Aerodynamics 4 02-14-2008 01:34 AM
