I like to compete in economy run events and have used a few different cars over the past few years. One I haven't tried yet was my '91 Sentra SE-R [2.0 liter - 5 speed]. It's been lightened considerably from it's original [approx] 2450 lbs. down to 2020 lbs.
![](http://img.photobucket.com/albums/v452/blownb310/DSC06153-1.jpg)
I normally use it for rallycross competition, but because of it's weight reduction, I decided to see what I could get from it in the recent
Tri-State Fuel Economy Run event. I had three 4'x8' sheets of black choroplast and some lexan recycled from another older project. The following are the mods I came up with from browsing these forums.
![](http://img.photobucket.com/albums/v452/blownb310/EconomyRunSE-R007-1.jpg)
First up was recycling the choroplast belly pan from my Datsun B210. The '91 Sentra is longer and a bit wider than the B210 so it isn't quite a full belly pan. This is looking from the rear axle area towards the front of the car.
![](http://img.photobucket.com/albums/v452/blownb310/EconomyRunSE-R006-1.jpg)
Looking behind the rear axle. To the left of the picture is the back bumper.
![](http://img.photobucket.com/albums/v452/blownb310/EconomyRunSE-R002-1.jpg)
Starting to fabricate the side skirts and rear wheel fairings.
![](http://img.photobucket.com/albums/v452/blownb310/EconomyRunSE-R010.jpg)
These are the rear wheel spats I came up with. I am wondering if I made them too big/wide?
![](http://img.photobucket.com/albums/v452/blownb310/EconomyRunSE-R002.jpg)
Front end closed in. I don't have the grill block taped on yet in this pic. I used a digital water temp gauge to determine the size of the cooling opening you see. The engine runs between 200-210 deg. F. The cooling fan comes on at 213 deg. Any comments or feedback are welcome on the profile I came up with under the bumper.
![](http://img.photobucket.com/albums/v452/blownb310/EconomyRunSE-R006.jpg)
I used a combination of choroplast and lexal pop riveted over light aluminum angle from the Home Depot. I mocked up the supports for the Kamm panel from cardboard.
![](http://img.photobucket.com/albums/v452/blownb310/EconomyRunSE-R008.jpg)
Then I bent them from aluminum strap. I used 3M body moulding tape to attach them to the trunk lid.
![](http://img.photobucket.com/albums/v452/blownb310/EconomyRunSE-R009.jpg)
Complete rear section. Now it was 2:00 am the morning of the event. Enough is never enough so I decided I needed to close in the front wheels as well. So I spent the next two hours fabbing up front wheel fairings. I wanted to connect the upper to the lower and build a full boat tail but ran out of time.
![](http://img.photobucket.com/albums/v452/blownb310/EconomyRunSE-R018.jpg)
After 1 hour of sleep I an ready to go on Sunday morning in Williamstown, MA for the event.
![](http://img.photobucket.com/albums/v452/blownb310/ecorun047.jpg)
The car performed very well, netting a result of 76.04 mpg over the 105 mile course.
I very much welcome any constructive criticisms as I did all of this from the seat of my pants with no angle measuring or tuft testing.
Thanks, Mike
