Old 10-05-2011, 08:38 AM   #22 (permalink)
320touring
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
Originally Posted by Arragonis View Post
You may need bigger pieces for the undertray, did you try the sign places too ? They often have smaller pieces (A3 is small) as offcuts. Small rodent houses are made from it too...
I have an e46 undertray at the unit, from the next gen 3 series.. both the e36 and 46 share the same suspension design/general dimensions, so I'm hoping it bolts right up (failing that, I'll "persuade" it to fit).
As for the Coro- 3x A3 sheets should be enough to block the upper and lower grills, surely?
or is that auction for 1 A3 sheet?
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
