Old 10-05-2011, 03:49 AM   #21 (permalink)
The PRC.
You may need bigger pieces for the undertray, did you try the sign places too ? They often have smaller pieces (A3 is small) as offcuts. Small rodent houses are made from it too...
Old 10-05-2011, 07:38 AM   #22 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
I have an e46 undertray at the unit, from the next gen 3 series.. both the e36 and 46 share the same suspension design/general dimensions, so I'm hoping it bolts right up (failing that, I'll "persuade" it to fit).
As for the Coro- 3x A3 sheets should be enough to block the upper and lower grills, surely?
or is that auction for 1 A3 sheet?
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
Old 10-05-2011, 10:08 AM   #23 (permalink)
The PRC.
No 3, that should do the nostrills I would think
Old 11-21-2011, 07:24 AM   #24 (permalink)
Team m8
Been in for it's MOT test today..
Failed on Rear Brake pipes (above the Fueltank and handbrake efficiency.
Awaiting info re cost before deciding its fate..
Hopefully it'll have a full MOT soon and I can get ecomodding..
Old 11-22-2011, 04:58 PM   #25 (permalink)
Team m8
Car now has a nice new MOT
the Ecomodding can commence
Hopefully get a bellypan fitted to the front at the weekend, and possibly construct a WAI to see if there is any effect
still at £0.24 per mile, including purchase cost/servicing/mot/tax and petrol
Old 11-23-2011, 03:29 PM   #26 (permalink)
The PRC.
Congratulations on the MOT - stuff can get expensive in classics
I would leave the WAI to last - I fitted a pipe from the inlet of the air filter to the exhaust on my trip to Inverness last week and measured an average of 55.5 on the trip there, I removed it and got 55.6 for the way back. Neither were correct as I got a higher average for the tank which was 90% this trip but there was no difference I could detect.
I think I may try a CAI instead for more oomph when I do accelerate (I have videos up in the George thread) - when time allows.
Old 11-24-2011, 07:51 AM   #27 (permalink)
Team m8
thanks!
Its the most modern car I own..was not too bad tbh, approx a months repayment on a newer car. (and not a 911 GT3RS!)
As for the WAI- I've been thinking about that- looking at my car it has the earlier AFM type air intake monitoring- its a flap, rather than an MAF setup..
I'm not sure it'll be able to detect a change in density?!
Old 11-30-2011, 04:04 PM   #28 (permalink)
Team m8
The MOT seems to have worked Wonders for MPG,
Just averaged 40+ uk mpg over the last 700+ miles, first time since winter set in..
car needs serviced badly, an 2 rear tyres- probably just go for some part worns...
Old 12-05-2011, 09:35 AM   #29 (permalink)
Team m8
fun times!
Old 01-15-2012, 06:15 AM   #30 (permalink)
Team m8
Updatte..
Finally got round to actually servicing the car
Managed to take some picturres of the underside to try and figue out how to mount a belly pan
and also discovered that BMW haave thoughtfully already installed a lower grill block
This is the back of the lower grill (please excuse the beardiness!)
