Old 10-05-2011, 07:08 PM   #284 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by PaleMelanesian View Post
I'm sure you know that 65 is too fast for good numbers. Your aero mods help, but the gearing is still working against you. You're running 2600 rpm at that speed. I aim to keep it below 2100 at the peak of my pulses, and even lower most of the time.
I have tried to follow your 2000/2100 rpm practice and can't get it to work for me. I don't know if it is the hilly terrain or enigine mods like the WAI and the 2* ignition timing advance or my working of the pedal. I just can't produce the results you get. In fact, my car will often lug if I try for anything above 60% load (approx) at 1500-1600 rpms (the start of a pulse). To avoid lugging (VERY bad for engine) I have taken to higher RPMs, such as 1700-2300. Second gear I push to 2500/2600 these days so I can have at least 1700/1800 when I hit third and raise the load percentage to 70 or higher. All my driving is pulse and glide, even on the freeway now. I hit 65mph, and I coast down to 55 and start over. That way I never drive below or above legal speeds. For my conception of my driving practices as being close to ready or ready for scaling-up, sticking to law matters (although I guess this is an odd way for a whole society to drive!!).
