Originally Posted by round.boater
Don't forget it's a complete log - I'm not cherry picking my fill ups. Some of those tanks have a utility trailer full of rafting gear. (Although not enough of them for how much I wish I were out playing...) Calculating the tanks without a trailer would make my Aerolid average look even better.
I didn't start logging while I still had my mechanical fan, so the first few tanks listed are up a bit from stock thanks to the e-fans and tightening the nut behind the wheel just a tad.
As always, good luck with the process!
round.boater, you mind if I ask how you calculate FE? Is it a manual calculation or do you have the Scangauge/Ultragauge? I ask because I'm considering buying a gauge and am having trouble choosing between the two.
