That tells me what I need to know. Thanks. It's a simple-ish mod, I may have to try it in the near future.
Oooh... Does it leave the fuel system pressured up? That's a problem on my car when it gets low - I have to cycle the ignition several times, to run the fuel pump, to get the pressure high enough to actually start the engine. I'd guess this would help with that issue by not running down the pressure.
