Old 10-06-2011, 12:28 PM   #11 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by PaleMelanesian View Post
That tells me what I need to know. Thanks. It's a simple-ish mod, I may have to try it in the near future.
Oooh... Does it leave the fuel system pressured up? That's a problem on my car when it gets low - I have to cycle the ignition several times, to run the fuel pump, to get the pressure high enough to actually start the engine. I'd guess this would help with that issue by not running down the pressure.
I don't KNOW the answer, but I have run the tank down to its last two gallons probably four times since the mod, maybe more, since this mod. I have never had to do what you describe, suggesting I may have better pressure in the fuel system.
Originally Posted by Old Tele man View Post
...I don't know how "physically" compatible they are with the HONDA, but the shift-quadrant selector handle on 2003-2008 Pontiac/Toyota Vibe/Matrix with automatic transmissions has a button on the side--just like you're re-inventing--that's used to "lock-out" (disconnect) the Over-Drive (OD) 4th-gear.
This is exactly the sort of idea I had. My goal was a shifter that was stock in appearance, so I got a stock 1998 Civic auto shifter knob! Fits the interior styling perfectly.
