Old 10-06-2011, 04:25 PM   #10 (permalink)
mcrews
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Originally Posted by Fr3AkAzOiD View Post
The car has a built in instant and average mpg display and while probably not as accurate as a scangauge it's good enough to easily detect a change of 3% or greater.
Not sure if I have a MAP or MAF. If it's important I can look it up.
I don't mind posting results that didn't work out. But right now I feel there isn't enough proof one way or the other. Even though I'm now expecting that it either won't make a difference or it will actually make things worse I feel obligated to do a second set of tests in the future.
Reason I tried this is due to a bad layout for setting up a warm air intake so I figured instead of getting less dense warmer air I would just reduce the amount of more dense cold air.
Idea sounded good at one in the morning ;P
Man, you had me.......rightr before the last SENTENCE!!!!!!
It's all good.
Keep thinkin and keep tryin.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
