Old 10-08-2011, 11:27 AM   #5 (permalink)
electricman
electricman
One Weeks Summar Log of the Loads with Electricfly
Originally Posted by MPaulHolmes View Post
ya! Post those buggers!
Ok - here is a Summary Sheet - in Excel, and a Tabloid Sized (11" x 17") pdf print of the same data.
It is just a set of key highlights, but fishing though a table in Excel with 32,000 lines is no fun, trust me!
True - actually having a Packtracker on a battery, with the woodward display - logging the data, while doing a load test on a Lab Bench would be even more definative, and controllable, but here are some high points, and you can be sure the max current points and minimum voltage points are within a few seconds of each other for the most part.
By the way - Have you checked out EV Fest 2011 yet?
Robert
