Old 10-09-2011, 10:41 PM   #386 (permalink)
Sven7
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
I've started shifting earlier. With less pedal pressure it doesn't sound like it's dogging so much at those lower rpm's. Hopefully 100-200rpm lower shifts will show up in tank averages!
Also, getting fed up with giving the thing too much gas and having to use brakes up to a red light. I bump start at 15mph right before stopping and idle at the light. Should I be leaving it off, and using the starter? I've done that a few times but it causes a second or two of delay when taking off on a green.
