Old 10-11-2011, 02:23 PM   #40 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by Vekke View Post
To folded mirror I would add small convex mirror to the tip that would work when the mirror is folded to be able still to see .
I used a small piece of aluminum cookie sheet to make a bracket at the correct angle and cemented it to the mirror glass near the hinge so it gives me a wide view when the mirror is folded. I stuck it on the glass with clear silicone sealant so I can hopefully remove it if the need arises.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
