Old 10-13-2011, 03:40 PM   #34 (permalink)
MetroMPG
90 day: 57.73 mpg (US)
More inflation vs. rolling resistance data for the pile.
It matches the previous tests (meaning, rolling resistance decreases significantly up to a certain pressure, then plateaus).
Tire tested: Bridgestone Potenza RE92 LRR tires in 165/65R14 size (Honda Insight OEM tire, installed on Geo Metro electric car - ForkenSwift)
Weather: 25C, 8 km/h SW wind (test course ran NW/SE)
Methodology:
  • tires were pumped up to 70 PSI, drove to test route (< .5 km), pressure adjusted
  • car was reversed up a small hill (approx. 2 ft. elevation) and stopped at a marked point
  • hand brake was used to stop - hydraulic brakes were not used at all during the test or on the short drive to the test area
  • transmission in neutral, hand brake was released
  • car rolled down short hill onto a flat run-out area
  • where the car stopped, the road was marked
  • pressure was adjusted (dropped 10 PSI)
  • rinse & repeat
Results:
For kicks, see also: comparing RE92's @ 50 PSI to space saver spare tire donuts @ 70 psi - http://ecomodder.com/forum/general-e...donuts-70.html
The Following 10 Users Say Thank You to MetroMPG For This Useful Post:
3-Wheeler (01-02-2012), Arragonis (10-18-2011), Daox (09-25-2014), Daschicken (12-01-2018), dcb (12-30-2011), diamondlarry (12-30-2011), euromodder (10-13-2011), jime57 (12-30-2011), LioNiNoiL (04-12-2013), PaleMelanesian (10-18-2011)
