Originally Posted by ihatejoefitz
What? ![Roll Eyes (Sarcastic)](/forum/images/smilies/rolleyes.gif)
Do you mean you don't know what hydrogen injection means or you don't think it would help? The idea is to use about 100 watts of electrical power to generate some hydrogen and oxygen gas from a tank of water and mix that with the intake air. The hydrogen is supposed to speed up the fuel burn and allow the engine to run on a lean mixture. I haven't tried it myself but I've read about it from several sources and believe it should work. It was recently discussed on a "Coast to Coast AM" radio program. You can read about it here:
http://www.coasttocoastam.com/shows/2008/05/08.html
I think that the fuel economy improvement might not be much unless the fuel system is modified for a leaner mixture. I think it might also be useful to mix some steam with the intake air.
