Old 05-16-2008, 08:38 AM   #21 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse (retired) - '97 Iron horse Intrepid
Ninja - '08 Kawasaki 250R
90 day: 76.23 mpg (US)
I would go with 5 main areas to expound on in more detail.
Instrumentation
Drive with a purpose
Pay attention(Situational awareness)
Follow the law and drive posted speed limit
Car in good working order.(tire pressures, engine, etc)
"Judge a person by their questions rather than their answers."
Old 05-16-2008, 09:37 AM   #22 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
I'm primarily a highway driver with an automatic, so here's my list (no particular weighted order of importance):
  1. Sufficient Practice from Instrumentation (know your vehicle)
  2. Scan the road ahead for adjustments (similar to situational awareness)
  3. Proper Tune (including underhood mods) and tire inflation -- (includes the engine block heater as an efficient "head start")
  4. Aero: Read the wind and adjust speed accordingly / avoid speeds over 60-65 unless coasting downhill / make aero tweaks if able
  5. Avoid idling
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 05-16-2008, 05:18 PM   #23 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
- Drive like a granny
- Off-peak commuting
- Use wifey's car for short low-MPG trips (thank you wifey !!!)
CarloSW2
American Solar Energy Society
Old 05-16-2008, 05:41 PM   #24 (permalink)
Depends on the Day
RH77's Avatar
Sports Cars
CarloSW2
My secret shame also revealed!
But then I get...
"I had it up to 32.7 and now it's at 32.3 -- what's up with that???"
Uh oh.
RH77
_
_
Old 05-16-2008, 07:46 PM   #25 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
1. Diesel engine
2. Manual transmission
3. Numerically lowest gearing possible
4. Clean up your aerodynamics
5. Keep EGT below 600 degrees and RPM below 2000
Maybe a bit esoteric but not repetitious.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 05-17-2008, 12:27 AM   #26 (permalink)
amateur mech. engineer
Sporty Accord - '88 Honda Accord LX-i
90 day: 23.25 mpg (US)
Dad's Camry - '01 Toyota Camry CE
90 day: 22.81 mpg (US)
Artie's Camry - '98 Toyota Camry
90 day: 37.3 mpg (US)
top 5 maintenance items:
1) Check for normal operating temperature. Install new thermostat if too cool.
2) Set ignition timing.
3) Make sure ignition advance mechanisms work correctly.
4) Make sure fuel mixture is correct by measuring oxygen sensor output or sniffing the exhaust. Replace oxygen sensor, temp sensors, vacuum hoses, intake manifold gasket or timing belt if needed. Check air filter and choke if engine has a carburetor.
5) Check for easy rolling by pushing the vehicle with the transmission in neutral on a level surface. Inflate tires, fix brakes or adjust wheel alignment if needed.
Top 5 modifications:
1) Warm air intake
2) Grill block
3) low viscosity synthetic engine oil
4) Fuel heater connected to heater hose or radiator hose
5) Hydrogen injection with lean fuel mixture (see www.hhowater4gas.com)
top 5 driving tips:
1) Drive between 30 and 60 MPH when possible.
2) Avoid excessive braking by allowing enough following distance, slowing early for stops.
3) Accelerate gently to avoid downshifts or release of torque converter lockup.
4) Follow large trucks on the highway to reduce wind resistance.
5) Shift to neutral when descending mild hills or slowing down gradually.
My goal was to list the things that give maximum benefit for the minimum cost and effort.
Old 05-17-2008, 12:45 AM   #27 (permalink)
is awesome
What?
KU School of Engineering
'72 Datsun 240z
'96 Chevy lumina
Old 05-17-2008, 11:48 AM   #28 (permalink)
Originally Posted by ihatejoefitz View Post
What?
Do you mean you don't know what hydrogen injection means or you don't think it would help? The idea is to use about 100 watts of electrical power to generate some hydrogen and oxygen gas from a tank of water and mix that with the intake air. The hydrogen is supposed to speed up the fuel burn and allow the engine to run on a lean mixture. I haven't tried it myself but I've read about it from several sources and believe it should work. It was recently discussed on a "Coast to Coast AM" radio program. You can read about it here:
http://www.coasttocoastam.com/shows/2008/05/08.html
I think that the fuel economy improvement might not be much unless the fuel system is modified for a leaner mixture. I think it might also be useful to mix some steam with the intake air.
Last edited by Andyman; 05-17-2008 at 11:55 AM.. Reason: make the link "clickable"
Old 05-17-2008, 01:04 PM   #29 (permalink)
2nd owner LW - '02 Saturn LW 200
90 day: 30.3 mpg (US)
magic van - '09 Honda Fit Sport
90 day: 42.31 mpg (US)
How much is shedding extra weight worth? Is there some scientific formula out there, like for every 100# less there is a corresponding percentage increase in MPG? Is it cost efficient to replace parts with carbon fiber molded parts etc.? New to the group and searching for advice.
Old 05-17-2008, 02:00 PM   #30 (permalink)
Recycling Nazi
Bror Jace's Avatar
Blue Bullet - '06 Honda Civic Sedan LX
90 day: 35.68 mpg (US)
Arrow
My list:
1) Slow Down on the highways
2) Increase tire pressure to max sidewall rating (or 1-2 psi less)
3) Pace traffic, anticipate the change of lights to minimize use of throttle and brakes
4) Remove unnecessary weight from the vehicle
5) Don't idle – avoid drive-thrus, warm-ups, etc …
I think these lists are worth repeating as the media does such a poor job covering this and other technical issues ... look at that recent article on CNN.com (link available elsewhere on this forum).
CarbonBuilder, that's a good question. Of course, I don't think there's an easy answer. I think weight matters more in stop-and-go driving and less on the highway where momentum works for you while weight works against you ... so they help cancel each other out.
One of the best tankfuls I ever got with this '06 Civic (about 42.5mpg) was when I was moving last year and my car was loaded right to the gills. BUT ... my move was in the middle of summer, almost all of the trip was highway and the traffic late in the morning and early afternoon was very light ... and the return trips (I made a handful) were completely empty.
--- Bror Jace
