Old 10-18-2011, 11:08 PM   #42 (permalink)
JethroBodine
MPG Militia HMV-25E80+A
JethroBodine's Avatar
FrankenJetta D - '90 Volkswagen Jetta GL
Diesel
90 day: 64.35 mpg (US)
Keep Jethro in line, THAT'S been tried before.
Got a little work done tonight. I scored half of a Handi-foam polyester spray foam kit, and nearly giggled myself to death waiting for quitting time. This was just what I was hoping for, and I wound up getting it before the rally this weekend. If I could have planned it, this would have been my first choice for build materials. When I wind up doing another, I will DEFINITELY use it by making a frame of stiffer and tighter wire mesh than chicken wire, and shooting foam over it. MUCH easier that glassing, in my opinion. I ran out before I could fill in all the low spots, but I can fill them in with body filler as I have time.
First coat of the spray foam. I trimmed off the high spots with an air saw that had a standard hack saw blade in it.
End view.
I was having so much fun that I forgot to take many pics of the second coat and trimmings, but here is a step in the sanding/shaping phase.
You can see where I ran out of one of the two chemicals on this view. I got those areas cleaned out as best I could.
As it is now. It is quieter than last night. There seems to be less air noise as well as deadening sound from the outside. I'll get a template overlay as soon as I get a good side shot. Long day.
It is always very amusing how our imagination is put to the test when overcoming reality. Redyaris
Boat tail project
How to gently bump start during EOC
The Following User Says Thank You to JethroBodine For This Useful Post:
Weather Spotter (10-19-2011)
