Old 10-17-2011, 09:51 PM   #41 (permalink)
redyaris - '07 Toyota Yaris
90 day: 45.54 mpg (US)
Gray - '07 Suzuki GS500 F
Motorcycle
90 day: 70.4 mpg (US)
streamliner1 - '83 Honda VT500 streamliner
Motorcycle
90 day: 75.63 mpg (US)
White Whale - '12 Sprinter 2500 Cargo Van
90 day: 22.01 mpg (US)
Originally Posted by deathtrain View Post
you know as much as i am on here i just now seen this.... so this is your trick to stay ahead. you evil B@#%!$D!!!! your cheating
LOL j/k man looks good. your going way more than i am willing to go.
Don't tell jethro, but you can keep him in line by instaling a belly pan and a rear wheel well covers and rear wheel mini boat tails and no one while see what you have done...
Old 10-18-2011, 10:08 PM   #42 (permalink)
MPG Militia HMV-25E80+A
JethroBodine's Avatar
FrankenJetta D - '90 Volkswagen Jetta GL
Diesel
90 day: 64.35 mpg (US)
Keep Jethro in line, THAT'S been tried before.
Got a little work done tonight. I scored half of a Handi-foam polyester spray foam kit, and nearly giggled myself to death waiting for quitting time. This was just what I was hoping for, and I wound up getting it before the rally this weekend. If I could have planned it, this would have been my first choice for build materials. When I wind up doing another, I will DEFINITELY use it by making a frame of stiffer and tighter wire mesh than chicken wire, and shooting foam over it. MUCH easier that glassing, in my opinion. I ran out before I could fill in all the low spots, but I can fill them in with body filler as I have time.
First coat of the spray foam. I trimmed off the high spots with an air saw that had a standard hack saw blade in it.
End view.
I was having so much fun that I forgot to take many pics of the second coat and trimmings, but here is a step in the sanding/shaping phase.
You can see where I ran out of one of the two chemicals on this view. I got those areas cleaned out as best I could.
As it is now. It is quieter than last night. There seems to be less air noise as well as deadening sound from the outside. I'll get a template overlay as soon as I get a good side shot. Long day.
It is always very amusing how our imagination is put to the test when overcoming reality. Redyaris
Boat tail project
How to gently bump start during EOC
The Following User Says Thank You to JethroBodine For This Useful Post:
Weather Spotter (10-19-2011)
Old 10-18-2011, 10:19 PM   #43 (permalink)
blownb310's Avatar
Saab EV - '19 Chevy Bolt EV LT
Pierre - '07 ZENN MC2 Base
Nice! Looks like you raised the level of the the top surface as per where the template overlay showed it was low. Very good.
2007 ZENN and 2019 Chevy Bolt EV 145,000 oil free miles to date.
Old 10-18-2011, 10:36 PM   #44 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Looks like it's coming along very well. Don't post this on VWVortex! :P
Old 10-19-2011, 06:39 AM   #45 (permalink)
Diesel
Love their site. I wouldn't post it on there until it was SHINY anyway, or had over 300 hp( this one never will). Although, if I took it to Boneville and ran it, that might make it OK.
Mike- Definitely raised it a bunch. Over 3 inches in some places. Probably not enough, but it is a lot more rigid and will be more likely to survive the winter better.
I didn't get to use my "calibrated hill" on the way home, but the wind noise was a lot less. I'll be filling up today or tomorrow to check how Version 1.0 did.
Edit: Tank for v1.0= 607.6 miles, 10.6 US gallons, 57.3mpg
Boat tail project
Last edited by JethroBodine; 10-20-2011 at 10:35 PM.. Reason: Brain dead, no coffee yet. 2nd for clarification
Old 10-20-2011, 05:19 PM   #46 (permalink)
Diesel
Quick update before I take advantage of the sunshine( all miles v1.1);
MPGuino = .99 gallons
Odometer= 80.2 miles
Boat tail project
Old 10-20-2011, 06:23 PM   #47 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Good for you!
I need to get a better base car to mod.
Old 10-20-2011, 07:15 PM   #48 (permalink)
90 day: 51.82 mpg (US)
Holy cow that's a lot of work.
Nice MPG numbers though.
Old 10-20-2011, 08:07 PM   #49 (permalink)
Sven7's Avatar
Whoa wait a second. You're getting that mileage with an 8V gasser? Holy shhhhhoot.
Old 10-20-2011, 08:37 PM   #50 (permalink)
Diesel
To get from how the tail looked previously to how it does now was about 4 hours, including sanding the old tail, wiping/ blowing the dust off, reading the directions, spraying 3 coats, shaping and sanding. This was quicker and easier (and funner) than building the frame( and I LIKE welding).
Also, hypothetically, I think that down my calibrated hill, tail 1.1 might get up to 83mph from a 45mph start. Probably be rock steady, too.
Sven7- I only checked the MPGuino as a lark. The odo said 80 miles, and I thought,"Wouldn't it be cool if I were still under a gallon."
Boat tail project
