Old 10-19-2011, 11:50 AM   #6 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by PaleMelanesian View Post
Right. 65 vs 70 sidewall almost covers the difference. I always assumed the 14's would have a close-to-accurate speedometer due to the slightly bigger tire.
Are you reading the speedometer mph or odometer miles? They're not always the same.
I'm reading the speedometer. It seems 2.5 mph HIGHER than actual speed (not percent but a consistent number of miles per hour, regardless of speed). The ODO I tried to calibrate against Google maps and found a 0.2%-0.4% UNDERcount by the ODO, but I think that test hopelessly flawed because the route was very very hilly and only 11 miles long. Later this month I try again with google maps, a good GPS that gauges altitude, and a 69.2 mile route that is fairly flat.
