Old 10-19-2011, 04:09 PM   #16 (permalink)
Arragonis
The PRC.
No Animated GIFs in Firefox.
Open a new tab.
Put "about:config" into the address box and press Enter - you will see a warning message about being careful, click that you will.
In the list look for an entry described as "image.animation_mode" (you can press "i" on the list and it should go there).
Double click on it, and change the text from "normal" to "none".
Animated GIFs will then be still.
