Originally Posted by F8L
You may need to inflate closer to 44psi which is right around max Psi for most 15" tires. I generally run 50psi on my 15s (max rating of 44psi). This has dramatically increased the rolling distance on coast downs.
Comfort is ultimately more important so go with works for you. I quickly grew accustomed to the extra harshn.
I can only assume you mean dramatically reduced rolling resitance, and leading to a longer coast down period, ie the car slows down less due to the tire being easier to push down the road. Why would you want to increase rolling resistance? This would require more energy to push the tire and therefore the car down the road.
