Old 10-24-2011, 11:43 AM   #1 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Civic break down
Car broke down last night near home. At cold start-up (60*) at the airport it revved unusually high (nearly 2000 rpms for a few seconds before coming down to normal). It ran quite normally for 20 miles, and then a hesitancy in engine response to the throttle returned. Alternator was connected and running. Battery power during EOC would settle between 12.3 and 11.8 volts depending on how long the glide was. A lurching ugly hesitancy emerged before the fail. When it failed it just gurgled itself into a slow die. Even a rolling bump start only acted as breaking. When it briefly sparked up a couple times, it struggled to sustain an idle even though it was already warmed-up. Then it died again for good. All fluids are fine. Car can still shift into gear and be pushed when in neutral or with clutch. Starter runs full tilt. No smell of fuel. No leaking fluids under the car. I was planning to follow advice and buy a pressure gauge today and test the fuel pump. I also am wondering about other parts: electrical components within the distributor? the cambelt? are those credible possibilities?
I'm off to the stores before work, during lunch, and after work... any advice greatly appreciated.
j
