Thread: Igor the Aygo
Old 10-25-2011, 07:49 AM   #32 (permalink)
Sykomor
Igor - '07 Toyota Aygo
90 day: 63.4 mpg (US)
Originally Posted by Arrow View Post
Have you tried bigger front tyres? In bigger i mean bigger diameter, this will lower your rpm at cruising speeds.
Also the aygo has a rear fenders which are almost designed to rear wheel skirts.
Skirts are on the drawing board.
I'm just about to order winter tyres but can't decide between the original 155/65-14 or the 5% bigger 175/65-14. It would lower rpm but 175mm is a lot wider. I could also try to find 4'' narrow 15'' rims to fit some 135/70-15. Suggestions are more than welcome.
...Hm, wonder if the Yaris 15'' tyres would fit...
