Old 10-25-2011, 05:25 AM   #31 (permalink)
Smart_CDI_2010 - '10 Smart ForTwo
90 day: 64.41 mpg (US)
G - '07 Volkswagen Golf MPV
90 day: 41.41 mpg (US)
Bigger front tyres and rear wheel skirts?
Have you tried bigger front tyres? In bigger i mean bigger diameter, this will lower your rpm at cruising speeds.
Also the aygo has a rear fenders which are almost designed to rear wheel skirts.
Old 10-25-2011, 06:49 AM   #32 (permalink)
Igor - '07 Toyota Aygo
90 day: 63.4 mpg (US)
Skirts are on the drawing board.
I'm just about to order winter tyres but can't decide between the original 155/65-14 or the 5% bigger 175/65-14. It would lower rpm but 175mm is a lot wider. I could also try to find 4'' narrow 15'' rims to fit some 135/70-15. Suggestions are more than welcome.
...Hm, wonder if the Yaris 15'' tyres would fit...
Old 10-25-2011, 07:39 AM   #33 (permalink)
Aygo rear wheel skirts
Bauhaus hardware store sells 2-side outdoor tape (Dubbelhäftande monteringstejp). The tape claims "permanent and steady attachment without screws".
I would first try a rear wheel skirt proto with this tape and some peace of plastic, in Aygo it really looks that simple to do. And when you get the results, then make a more permanent installation. But this could be the easy & fast solution to get the data.
Before the 2-side tape loses it's grip you'll have enough info.
The Following User Says Thank You to Arrow For This Useful Post:
Sykomor (10-25-2011)
Old 10-25-2011, 08:29 AM   #34 (permalink)
The PRC.
If you have lowered the car then larger tyres may hit something ? Not sure, but I have read about kids fitting 15s to their cars and having issues.
EDIT - it may have been 16s with wide tyres...
Also not convinced gearing is going to solve the FE at speed balance - you still have to push the throttle to maintain speed and in a higher gear the push is for longer.
I've started using a version of "LOG" without the "engine off" part. Will see how this goes.
Old 10-25-2011, 02:25 PM   #35 (permalink)
Originally Posted by Arragonis View Post
The language is fine.
What does your insurance say about mods like lowering ? If I do that here they want mega £s extra and one of the savings with George is the lower insurance - I'm aiming for £150 instead of the £375 the fabia was costing me.
Hopefully my front grill will be blocked this PM, after usual family stuff of Sunday mornings...
I got an answer from the insurance company (Länsförsäkringar): The lowering does not affect insurance cost.
Old 10-25-2011, 04:09 PM   #36 (permalink)
The PRC.
Good news!
Old 10-29-2011, 09:51 AM   #37 (permalink)
I had a good tank (65.35) but not as good as it seems. I "added" a factor 1.046 to the miles as according to several gps-navigator tests show that I actually get 4.6% longer than the odometer indicates. I have calibrated the UltraGauge accordingly.
Away to test bigger wheels and planning for kammback...
Old 10-29-2011, 11:47 AM   #38 (permalink)
The PRC.
What type of roads (urban, highway, motorway) and what % do you typically drive ? I at most do 50:50 urban and busy bypass - motorway.
Old 10-29-2011, 02:09 PM   #39 (permalink)
Ideal actually. Speed limit 70km/h (43mph) some 80 km/h (50mph) and a very small part 90 km/h (56mph) The last km is citytraffic. I can very much choose what kind of driving I want. A bit hilly at parts though. I also have a few stop signs, and one stopsignal if I'm unlucky.
Old 10-29-2011, 02:43 PM   #40 (permalink)
I just tried the wheels from a Yaris: 185/60-15 and they almost fit (108,1% diameter). That means I can have the bigger diameter I want and go up to at least 175mm width. In Sweden it is not illegal to have 5% larger diameter.
I'm thinking Nokian Hakkapeliitta R
100% 155/65R14 75 R
107,9% 175/70R14 88 R XL (almost legal)
104,7% 175/65R14 86 R XL
110,4% 185/70R14 92 R XL (illegal)
106,8% 185/65R14 90 R XL (almost legal)
If I can find some 15'' rims there's also:
109,1% 175/65R15 88 R XL (illegal)
Which should I choose? I would very much like the Hakka but there's also other makes.
105,3% 165/70R14 Kumho, Hankook, Sava, Fulda, Dunlop…
This tyre size calculator is really good by the way: rimsntires.com/specs.jsp
Help me choose.
