Originally Posted by jkv357
Comparing bicycle wheel bearings to engine bearings isn't even a remotely close comparison.
I said wheels ball bearings meaning on the wheels of cars, trucks, busses etc.
Which acid do you mean where the acid will come from!? if the acid will go in the oil why the oil level does not increase!?
Small amount of smoke from the combustion chamber is totally nothing as it will not harm oil at all. The oil does not mix with other liquids.
Think logical dont be based on what others tell you.
It takes a genious to see the obvious. - Einstein said.
Compare ball bearings oil (lowest quality lubricat; grease) with the engine oil. Why we never change the grease on the wheel ball baerings and they last for decades!?
