Old 10-25-2011, 04:57 PM   #159 (permalink)
kach22i
Some of you have taken the position that a larger trailing wake is lower drag than a smaller trailing wake. Doesn't make sense to me.
The trailing wake in all examples given starts at the top of the rear window.
From that point we have several options;
1. Roof spoiler, creates vortex which eventually manages to pull the flow downward in a more controlled manner.
2. Plane above the window (should tilt down 10 degrees but is shown flat) which extends the length of the car. A longer car should move through the air better, but with some additional surface drag. This is similar to the aero-mods many people are doing in this forum.
3. A flat plane, marketed as a wing, secured tight to the body below the rear window, and completely out of any known air flow pattern. The pattern we do know about is turbulent and full of drag.
If we could put the VW Beetle though a wind tunnel ourselves and experiment with many different positions and shapes, spoilers, wings and planes, we might come up with something none of us could have ever predicted.
I did this overlay (not to scale) to get an idea of what possibilities may be out there.
Automobile pictures by kach22i - Photobucket
