Old 10-25-2011, 10:36 PM   #10 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by Ladogaboy View Post
Bummer. I hope you can get it up and running again soon.
Fuel pump seems to work, at least it gets power to do the normal priming when the key is switched to the "run" position. And I just finished a fuel filter change and replacing the "igniter" a.k.a. the ignition control module a.k.a. the ICM. No dice. No change. Same symptoms. Help.
