Old 10-27-2011, 12:09 AM   #144 (permalink)
jkv357
Originally Posted by JRMichler View Post
Good clean oil is important on the cam lobes. The high loads and small contact area result in a thin oil film. Dirt in the oil acts like grinding compound and wipes out the cam lobes.
(SNIP)
That may be even more true now that regular auto oils have lower levels of Zinc and Phosphorus (ZDDP) to help the catalyst have a longer lifespan. The lower levels can present galling problems for cams with non-roller lifters - especially at cold start-up.
"Racing" oils generally have higher levels, as do most cycle-specific oils.
Most, but not all, diesel oils still have higher levels. One interesting note about Shell Rotella - conventional and synthetic multigrade oils both have high levels, but the straight-grades don't. Go figure...
