keep your revs under 2500 and below 20% throttle, also you can get a wide band o2 sensor and see exactly what fuel enrichment you are running. I believe there is a way without getting a whole new o2 sensor cause honda has the 4 wire sensor.
I never owned a VX but from all the info I also picked up stepping on throttle each gear 80% up to speed and shifting before 3000 rpm until you hit cruising speed will help. I am in for a 95 CX model EG6 next week if the lien sale papers go through and the title is clean. 91K miles white!
