Old 10-30-2011, 12:28 PM   #3 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Originally Posted by jakobnev View Post
Maybe it has a TPS with a voltage signal?
Yes, it does and adding sensors on is not an issue, but the engine already has the full range of sensors needed and they all feed in to the computer with a nice OBDII plug that allows my scan gauge to read that info, so why not use that plug to talk right to the speed controller, that is if it works, right?
It sounds tho, like the CAN-bus bar that the OBDII plug is taping in to can have a lag time because of slow refresh rates and if that is the case then my idea might not work, but if the refresh rate is quick enough then it should work just fine.
