Originally Posted by skyking
Thank you very much!
To be clear, I would need both side cams installed but never need to see all three cams at once. I would rather have the biggest split screen and chose between left or right side cams as needed.
When backing the far side is blind, the near side is totally covered by the mirror.
That brings up my next question. Do you want to mount the side cams on the truck or on the travel trailer? If you mount them on the truck you lose sight of either side past a certain angle but you have them for the truck all the time.
If you mount them on the sides of the trailer all the way to the front, then when you back up at an extreme angle you still have 'eyes' on what would ordinarily be your blind side, but they don't see traffic next to the truck. The other thing is, if you mount them all on the trailer you'll need one more trailer connector to hook it all up. Or you use one big Deutsch connector. Not a big deal just details.
