Old 11-01-2011, 06:40 AM   #146 (permalink)
Vekke
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Originally Posted by cycleracer88 View Post
Excuse me, but you have two bugs in your project. You delete the intercooler? Why? ... the component is necessary to run efficent with the tdi! You installed the intake pipe on the right car wing. This isn't a good position. On the front is more efficent! Because there you have a ram pressure. So your compressor don't musst draw so much ;-)
For intercooler I dont need it when driving fuel efficiently and speeds under 100 km/h. temps are under 50 celsius. On todays aba test the intake temps were @ 75 celsius at 130 km/h speed. Also the cold winter is coming and it is totally useless at least then. It colds down the engine when you try to make it warm. Someone should calculate what is the 02 difference if intake temps are 20 celsius higher. Also there is no turbo lag and pressure lost in pressure pipes so the turbo dont have to work so hard.
On winter I will have to insulate the engine to make it warm enough.
The cold air intake was just a first aid to make the intake temps lower without intercooler. Place of that intake will change in the future. If I make different kind of setup to intake it takes lot of time due to winter times. If system is designed bad you will brake your turbo with frozen ice in the intake which is then sucked to the turbo. That happened in my hobby car in just 50 km of driving when temps went below zero degrees...
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
