But Artan, why do you clean your air filter so often? Unless you drive on very dusty roads all the time, it seems like spending a lot of time. I maybe check and clean my filter every 5000km unless there is a lot of driving on dry gravel.
How much oil did you add when you changed your oil filter? If it was a litre then you added fresh additives for a few more thousand kilometers, so technically you are still in the safe zone with this oil that is meant for 30 000kms.
